1 - 13 of 13 Posts
06 DC Limited, unclear what the "Shift L" button is on the dash, the owners manual seems very vague. TIA
Chuck
Professional Driver
Toyota got lazy when they switched to the 5 speed tranny in '05. Instead of modifying the shifter/steering column for the extra gear, they just put a button on the dash. Its the same as if there was one more position for your shifter for 1st gear.
  • Like
Reactions: SC T100
It took me a while to figure that one out as well, My friend who is a Toyota mechanic didnt even know what it was for. Shift to second and press it. A little L should appear next to the 2 on the gear indicator. Its basicaly first gear. Works well along with 4x4 low.
I use it here in the really slow construction sites. allows the truck to just creep along without constantly going from the gas to the brake.
Always wondered when I would use it. Couldn't think of very many situations you want want to be locked in low.
Or just hit the button again if the shifter is in 2nd.
1 - 13 of 13 Posts
