Yeah you don’t have to replace the springsYea after research I found that out. And yes I do all my own stuff unless I just dont have the tool. Cant I just replace the shock and not the coil
spring?
need a spring compressor. yes, can be very dangerous if you aren't watching what you are doing. I've done 15-20 sets myself, long as you use the compressor correctly you are fine, can pick them up at any auto store for free rentalIs it fairly easy or do I need a spring compressor of some sort to get them off and on? Spring under load? Dangerous?
Yes.Are the shocks fluid filled?
