Replace the turn signal flasher unit with a flasher for your vehicle but without DRL's. Cost at the Toyota dealer was $67
You will now have regular park lights (not bright like the DRL) and works off of your switch and under your control.
Flasher location
Remove the lower dash panel under the steering wheel, 2 bolts at the bottom, 4 snap locks on top. Flasher unit is on the left upper side of where you can reach and attached by 1 nut.
