I have a 2008 5.7L that keeps burning out lightbulbs on the front end. Both turn signal bulbs and headlamps.
I have owned the truck for about 18 months and have had one single bulb go out on the headlamp 3 times, twice on the passenger side once on the driver's side.
A signal lamp on the front turn signal has also burnt out twice, I can't recall which side.
The socket on the burnt out bulbs was charred on the edge from heat. I'm not sure how normal this is.
I replaced with a standard replacement each time. I don't think it is a problem with the lamps themselves. Maybe overvoltage issue?
I'm looking at changing the headlights to LED bolt ons and I am concerned about burning out an expensive LED assembly. Any comments or known issues?
thanks in advance,
thanks in advance,
