Hey guys new to this forum I have a 2002 sequoia that I'm having an issue with that I can not figure out a solution to. When driving on the freeway at 75 mph the steering feels very floaty and I feel like if I had to make a quick move this car would flip. I do not allow my wife to drive it because of how it feels I'll list below everything I have done.
Replaced Rack and Pin bushings
Replaced upper control arms
Replaced front struts
Replaced both lower control arms
Replaced both sway bar links
Replaced driver side upper ball joint
Replaced driver CV axel
Replaced Driver ABS Sensor
Replaced Driver Wheel Bearing
Replaced both front rotors
alignment was done and no change in the feeling.
Both lower ball joints replaced 2-3 years ago from dealer recall.
Current setup 285/70/17 with a 2.5 front spacer leveling kit. and wheel spacers.
also when taking fast curvers my traction control always comes on too when turning to the right.
I'm starting to feel this floating issue and traction control issues are all related to the bigger tires + Lift + Spacers. I'm almost considering just going back to 265/70/17 to see if there is any difference to my issue.
Thanks guys
Thanks guys
