Apparently the skid plate bolts (rear part of the skid plate) fell out or were not put back in after the last oil change, so the entire skid plate is hanging down. Does anyone have a link to the correct replacement bolts? 2000 Trundra SR5 4x4
It would be the bolts for the top part of this image in the deep wells. (image plucked off the Net)
152223
Toyota bolts are all pretty standard. If no one chimes in with the exact bolt for you 10mm head has a 6mm x 1.0 thread, 12mm head is 8mm x1.25 thread, 14mm head 10mm x 1.25 thread. That covers most basic bolts they use. I think the back ones are 12mm head with 8 x 1.25 thread. If you go to Home Depot they would probably let you walk out with one to test for sizing. Just get the right size in a rust resistant bolt like a zync coated one
