Hey i was just wondering if there was anybody out there with the TRD skid plate having a fitment issue? The plate just doesn't seem to tuck up against the body like it should, or at least compared to some tacomas i've seen, I also may just be to nit-picky? Anyways the instructions call for a maximum gap of 20mm from bumper to plate and I'm at about25mm+. I've tried everything from repositioning it and bending it up while installed with no luck (strong stuff). I also installed mine myself and the ones i've seen with smaller gaps were factory installed.
10mm?! thats pretty close, did you install it yourself or the dealer/factory. My gap is just too much for me I'd like to be around 10-15mm also, probably closer to 15 cause i don't want any rubbing. If you did it yourself did it just come out like that or did you have to adjust it a lot to get it so close?
i put mine on myself and this is how mine looks. I pushed and pulled a tad to get it even from left to right, but thats about it.
hopefully this picture shows the gap good enough.
