2004 Tundra Dbl Cab 2WD. For the past year or so when I turn the wheel to the left it sounds like something is grinding
on the front end. I've looked under the truck and can't see anything. My mechanic said it was a loose cover panel underneath.
But after he (so called) "fixed it" the noise is still there and getting worse. It only happens when the wheel is turned about 1/3 to
the left. It makes noise halfway in a left turn from a dead stop. And also when backing up slowly with the wheel turned slightly
to the left. What should I check? I don't want to take to the Dealer $$$$ and my mechanic can't seem to figure it out.
Any help would be greatly appreciated.
