Hey guys new to the forum
I have 2007 Tudra 4x4 5.7.
I purchased a Rough Country 6" suspension and a 3" body for my truck.
I cant decide what tires and wheels to go with.
Things i need input on:
37 or 38 ich tires? *x*x*
Wheels????? tooooo many to choose from. The only thing i know is i want chrome
Any input would really help me out.
Stick out a tad id say, probly a inch or two.
was thinking of 37x13.5x18 Dick Cepek Radial Mud Country
Let me know what you think.
and i still cant decide on a rim. looked at the moto metals and are leening towards them
Size 18x9 ET0 (5" BS) will be the most ideal for tire size 37x13.50-18. Compared to where the OE tires and wheels sit, the 18x9 ET0 with 37x13.50s mounted will push out 3.7" further towards the fender. This should put the tire outside of the fender by 2.25". You should also be able to get away with a +12mm offset on an 9" (5.5" BS) wide wheel but I suggest running a 12.5" wide tire.
Don't get the DC's, I've heard bad things about them between balancing and tread wear. You should easily fit 37's under it, however, make sure you put in the steering bumpstops on the axle, otherwise you will be scrubbing all the time. I never went wider than a 12.50 on mine and had no issues.
