1 - 7 of 7 Posts
Folks, I have searched and found no reference to my newly found problem...
On my 07 DC - I started the truck Tuesday morning and the Sonar goes into a blinking mode... Indicating front end signal. After reading the manual it says essentially "you have a problem ... go to dealer". Shutting off the Sonar shuts it down and no noise.
No rain, Not close to wall or object... did not hit anything. I noticed nothing prior to shutting off Monday night...
I will crawl underneath this evening and see if there is anything to see ... like a lose wire or dead rat or snake or whatever....
Any one have this problem before?? Any thoughts?
Thanks for any help.
My rear right used to do that, would be going off for no reason, but i just turned it off for a little bit then back on and it was fine. I'm sure it'll go out in september when my warranty is over
did u try wiping off the sensor??
3 years on the farm, gets harsh during winter days. Never had an issue so far.
Though sometimes I do forget to turn it off when the trailer is attached, surprises me when I back up :D
Took a look today... cleaned off the front and back. Can't see anything lose or whatever....
Same annoying noise letting me know it is not working.
Next time I am near the Dealer I will have them look at it...
Thanks for the help...
Mine did the same thing took it in and the right front sensor went bad. Took 5min to replace and haven't had a prob sense. Hope its under warrenty cause the sensor was like 200 bucks.:)
1 - 7 of 7 Posts
