Not here... I did test drive on with the sonar though it has a button on the dash to turn it on.In Canada the sonar is part of the TRD offroad pkg
Your dealer screwed you. He wanted you to get that port sonar because he made more money on it charged you more than the factory and gave you half as much. It doesn't work the same as the factory either. You CAN get it factory in the SET area but you would have to order it that way. They won't tell you that and you probably won't find one on the lot with factory sonar in the SET area because they don't make as much money on the factory one. Don't buy that SET port crap you will regret it. Plus they replace the bumper with a cheap after market resin bumper.In the Southeast Toyota, it is an accessory. I orderd mine with the TRD and had to get it installed at the port for 460 extra just rear though not front. I am going to buy the rear cam myself and do it, because it is a lot cheaper than adding it through the dealer.
sonar? for when the truck is underwater? and when would that be?
Um, Toyota factory sonar option is $500Your dealer screwed you. He wanted you to get that port sonar because he made more money on it charged you more than the factory and gave you half as much. It doesn't work the same as the factory either. You CAN get it factory in the SET area but you would have to order it that way. They won't tell you that and you probably won't find one on the lot with factory sonar in the SET area because they don't make as much money on the factory one. Don't buy that SET port crap you will regret it. Plus they replace the bumper with a cheap after market resin bumper.
------------------------------------------------------------------------Your dealer screwed you. He wanted you to get that port sonar because he made more money on it charged you more than the factory and gave you half as much. It doesn't work the same as the factory either. You CAN get it factory in the SET area but you would have to order it that way. They won't tell you that and you probably won't find one on the lot with factory sonar in the SET area because they don't make as much money on the factory one. Don't buy that SET port crap you will regret it. Plus they replace the bumper with a cheap after market resin bumper.
why would you need a sonar when the back up camera is there..Secondly ,i hate it. you still have like a foot and the thing alarms like your going to wreck something. i have it in my odyssey and i alway turn it off...because when getting into a tight spot and your commited it throws you off..i always have it off...
my 2 cents
Lemon
Depends on what area your in.Lemon,
According to the installation manual for the backup camera you cannot install the backup camera without the Sonar and/or the tow kit. If you buy an SR5 with the TRD package you are S.O.L. if you want to add the backup camera, because it doesn't come with either the sonar or the tow kit.
