1 - 7 of 7 Posts
Hi all, filled my 04 Tundra up yesterday and noticed that the spring door at the top of the fuel spout was missing.
My guess is it went down into the tank.
Any ideas how I could get it back out?
I still have full warranty on my truck, any idea if this might be a warranty issue?
Thanks.
Ever the explorer
To get it out will require draining and dropping the tank.
It might or might not be a problem leaving it in there. In the old days prior to unleaded fill tubes we had problems with the old pop bottle caps being dropped into the tanks. They would circulate around and get sucked onto the fuel tube, vehicle would stall resulting in loss of suck on tube. The cap would fall loose until next event.
Any chance someone's tried to siphon your gas? Lotta times, when they do, I've seen where they've bent that flap aside or broken it completely off in the process of pulling their siphon tube back out.
There isn't a spring loaded flapper, not on my 2001 at least. I recall an old thread about this.
1 - 7 of 7 Posts
