I have an 2008 tundra with a shifter that squeak's everytime from park to reverse and the to drive. i have tried putting wd40 down the shifter and that has not worked. does anybody else have this minor problem and if so do have a fix for it.
thanks
Could be the cable, or the pivot pin has dried out and making noise, not sure. You are probably not going to
be able to reach those areas to lube them without taking the console apart. (this is assuming you have the
console mounted shifter - you did not specify) But if it is still under warranty,
take it to the dealer when you have time and let them deal with it.
I have the same problem, let me know how it goes for you. Everytime I go in for service i forget to mention it
I have to say it... Is this really a "problem" worth worrying about??
