1 - 8 of 8 Posts
Does anyone know where I can buy a conversion kit for my 2006 Tundra SR5 Access cab, so that I can get rid of these rear drum brakes and put on a set of SS brakes and calipers. I sure wish I would have had the bucks to buy a 2007, the brakes on this 2006 are worse then my old 1988 Jeep. Please advise.
Adding the discs to the back will not give you much better stopping power, only the clean disc brake look. Go for a big brake kit for the front and that will be all you need.
There is a lot more to rear discs than just the looks. They are fade-free, less likely to lock up (even with ABS, drums are self-energizing) and pad replacement is a piece-o-cake compared to shoe replacement. Discs have much better performance in wet conditions. The drum brakes squeal and need a self-adjusting feature that is not always reliable (disc calipers do not).
I'll take disc brakes over drums any day.
JMHO
Dan
Trust me rotors are so much better then drum brakes. My friend has a 1964 Bel Air with drums. It takes a long time to stop. However, the Bel Air is a HEAVY car. If any one is intrested he is selling the Bel Air, in great condition, I belive he wants $10,000 for it.
Disc brakes do stop better than drum brakes. Guess what the front/back ratio is for the braking power though. Not 50/50. More like 70/30 or 75/25. The back brakes help, but the majority of your braking power is the front.
I had the Stoptech 332mm big brake kit on my truck. I could stop faster from 50mph than some old lady doing 10mph in her buick. 2 Piston design with slotted rotors and stainless lines is going to work a hell of alot better than replacing your rear drums with discs.
Like others said, the front brakes do the most, improve them...$1000+/- for the kit, do you think you'll get that much more stopping power? CSM-H
i need to get new drums and dont want to spend the money to convert to discs? has anyone used the after-market wheelers drums???
1 - 8 of 8 Posts
