1 - 9 of 9 Posts
Hi I have 2002 Tundra Access cab and the black trim on both front doors the black is coming off ( the base of the windows). Under the black is chrome. What is the fix for this, the black is a lot thicker than paint it is like a plastic coating. What are some of fixes for this? Thank you
Its called a belt molding or belt weatherstrip and its somewhat of a common problem. And not exactly cheap for OEM.
I bought all 4 for my 06 CC. Plus the 2 rear/top as the exterior window seals on old are getting ratty. Finishing a full mechanical fix from front end to back bumper then learning some PDR/DR & painting/corrections and putting all on as I am finishing the Final Wax Buff!
They are relatively easy to R&R with care & patience.
But expensive like Cheapskate said. If the rubber seal strips aren't rotting that paint job fix sounds solid until they do.
Order Content
Part NumberPart NamePriceQuantityTotal
75710-0C010Belt Weather-Strip$100.291$100.29
75720-0C010Belt Weather-Strip$100.291$100.29
75730-0C022Belt Weather-Strip$82.391$82.39
75740-0C022Belt Weather-Strip$82.391$82.39
Subtotal:$365.36
Also, Mine had some deformedies on both the old frame molding. Also the rain drip moldings and rear end caps as well as right wheel well molding extension/protector and brand new rear bumper to give the girl a real nice 15 year anniversary full body treat.
She is worth it!!!
I cut the dilapidated and horrible looking remnants of the molding on the lower windows away with an X-Acto knife, the taped it off and sprayed it flat black, too. It made a world of difference and was cheap and easy. Good luck.
1 - 9 of 9 Posts
