I had a weird problem yesterday when I tried to start my truck. When I turned the key to start the truck it started and then died. On the second attempt, it wouldn't start and when I released the pressure on the key, the starter continued to run for about 3-5 seconds. I let it sit for a minute or so, I could get it to start by pressing on the gas pedal, but it would die immediatly. So I swapped out the fuel pump relay in the engine compartment fuse box with another one. (they are blue and have 5 posts)!
The truck started and did not die. I swapped the relay back to their original posistions and it has been running and starting as it should!
Just wondering if this has happened to anyone else?
