I just purchased set of center caps ( and clips) for my OEM steel winter rims but thy barely hold on those rims.
I tried to slightly increase the tension on those SS clips but it doesn't make any difference.
Anyone using them?
i had some of them at least i think i did! you need to remove the wheels to get the clips to hold correctly. i had luck pushing on them really hard, but when i removed the wheels for my new ones i found they were not locked all the way. im just lucky i didnt loose one.
did they look like this?
Thanks for reply :)
The rims are not mounted :(
The plastic of the cap is tight to the rim mounting holes but on the outside there is about 1/8" gap
Clips are flush with the inside of the rim.
@deviltundra
What kind of lugs you use to mount your steel rims?
Do they have washers that would hold the center caps on?
