1 - 7 of 7 Posts
Thanks to everyone here, I got enough information to believe my setup would work, but I couldn't find someone with my exact desired setup.
I purchased a set of Raceline Raptors 18X9 with +25 Offset to replace the stock rims on my Tundra. I put 305/60/18 Nitto Terra Grapplers on and they clear the suspension and the fender liners at full lock.
EXCEPT at the front of each inner fender there is a small, bolt on dirt shield that only has two bolts in it at each end. It flares in toward the tire in the middle of the shield. When the truck is in reverse at full lock, the Nitto's just barely rub on the shield. So...I'll either remove the little shields or put a screw in the middle of them to keep them clear of the tire.
I like the rake of the stock suspension setup and didn't want to add a lift, and it works great.
lets see some pics!!!! im sure the truck looks sweet.
I bet it looks great for the wheel gaps.. one concern is speed bumps and curbs.. curbs are avoidable but its nice to be able to get over them when you need(I.e putting a boat in a side yard to wash it)
It's a 5 minute job (if that)... take them off and put the bolts back in and you'll never know it came with them...
Sounds good napoleon and welcome aboard.
Do you have any pics of your truck up close with the raceline raptors. I have the same style tundra and I love the rims. Thank you
1 - 7 of 7 Posts
