2005 Toyota Tundra 4x4 limited double cab 4.7l
Installation is a bit unorthodox. None of the adapter bolts in the kit fit you have 2 options open the top of the mount just a little bit so one that fits the threads of the stock mount can be used or... What I did I took a m6x1.0mm tap and cut new threads in the stock mount the end result was the brass connection being uniform all the way down and the m6x1.0mm to m6x1.0mm adaptor was then used. To mount the antenna. I seem to still get reception not sure if range is diminished.
153323
153324
153325
Discussion Starter #2
This was also 18.99 at Napa.
