Hey there, I just bought a really 2004 Toyota Tundra Double cab limited. I've only had it for a few weeks but I've noticed it seems to be lacking a bit in power, leaking a little antifreeze though the only indicator is that the reservoir goes to empty without a drop/smell of antifreeze anywhere. I'm also getting 480km to 90 litres of gas, or 290miles to 23.7 gallons. I know it's a V8 but this is brutal mileage. It has a cold air intake placed by the previous owner and sits on 31" BFG all terrains. I have had it at the shop now for 2 days, and they cannot find what the problem is. MAF sensor was fine, as was the air temp sensor. There was a vacuum hose hooked up incorrectly to the intake tube of the cold air intake but that has been since corrected and moved to the proper place. It was mostly highway/logging roads, driving very conservatively. My concern is that it may be the head gasket. Any ideas before I go down that expensive road!?!?!? I'm sure it has something to do with the computer, I just don't know what...or how to find it, seems as though no one can.
Spark plugs have been replaced, oil has not been changed and there is a bit of a ticking sound at high speeds.....
If anyone can help I'd be forever grateful! The mechanics just can't find the problem. OH, and after I took it home from the shop, 15 minutes later drove to work and check engine light came on....brutal!!
