Okay all the Supra experts out there, I am preparing to do a front wheel bearing replacement on my '89 NA. I thought while the front end is apart to check and replace lower ball joints and tie rod ends if they indicate wear. What special tools will I need and can they be rented from most rental stores? Any words of advice you can send my way will be appreciated. TIA.
Al
nice ride, good year. :tu: :tu: :tu:
wish i could help you there, ive only evey repacked the front wheel bearings only. never got much further into my suspension on my ole 89 supra. already sold.
All you'll need is a tie rod puller if that. A hammer is usually all u need to seperate the bolt from the mount.
