I have a 2006 2wd V6 4.0 with 3.91 gears. Can I put in another rear carrier from any other tundra 00-06. I was looking to put in the factory 4.10 rear carrier because i'm running 33's and I want my lower-end back. Is it possible to use a rear locking one as well.
I believe only 04' Dcabs had 4.10 gearing. You would have to find one from that truck and it should bolt up with no problems. Usually the Dcabs have LSD which will be better then and open end (no factory lockers in Tundra's), if not then you could always put in a autmatic locker or a selectable ARB!
