Ok Folks...
I bit the bullet and tried the Tacoma Fog Light mod on my '07 Tundra.
http://www.tundrasolutions.com/forums/tacoma/57319-how-to-fog-light-modification/
The mod is supposed to let you run the Fog Lights anytime.. With or without headlights and with high beams on. Instead of the way it is: Only when low beam headlights are turned on.
I have a co-worker that has an '05 Taco and he has a friend that has an '07 Taco. Both work with the same mod, so I figured the Tundra would do the same.
I did option 3 in the above thread.. No worky..
The relay is set in the box where one of the silver pins is closer to the front of the truck and the other is closer to the rear. When you bend and hook up the front pin, the fog lights won't come on at all. No matter what. When you bend and hook up the rear pin, the fog lights will light with no other lights on, but they will turn off as soon as you turn on the parking lights or head lights and will only turn back on when all other lights are off (except DRL)
No mod ever mentioned bending the copper pins, so I didn't touch those.
When all was put back to original, everything works fine.
So, I have tried and failed using the simple Tacoma Mod. Who out there is smart enough to take my info, use it for what it's worth and come up with an '07 Tundra Fog Light Mod that works?
Hopefully someone, because, evidently, I can't.
