This part was a recall but not covered for my vehicle. So, I bought two 81555-0C010s "Socket & Wire RR Combin", Replaced the left side wire, put it all back together and no turn signal but double time in the front. Good bulb, good fuse. At a loss. Any insight would be greatly appreciated.THANKS
:selfdestruct:
were both wires the same number? 81565-0c010 might be left side. back to basic, test light time to make sure you power coming out of truck harness. if there is power call your parts guy make sure right part. look at both plug ends make sure the male wire ends all have a female wire end to match them. double time flashing usually a short or a major load on curcuit.
