1321 - 1339 of 1339 Posts
Re: The Official "How to add MPG buttons" thread (some conditions may apply)
hello everyone I live in Hemet , ca if anyone of you has done this mod and willing to do mine I will pay you for your time do mine....I have a 2010 tundra 4.6L base when I look behind my blacks the plug has 6 wires I do have a switch already just hope it the right one ….if not maybe you could do all the wiring so when I can get the right one all I have is plug it in and be done....I can come to your place or you can come here within reason I say 60 miles away is the most....contact me here and we set up a price and time.....thank you and marry xmas 2018 :)
Success! I just bought a 2007 SR5 double cab with 27500 original miles! I really wanted the MPG button. It was a little over my head with out pictures but I got it done thanks!!
Alan
Great information. I will have to see what I have in my truck.
I cannot get this to work. I have a 2007 CM SR5 with bench seat and have added:
- 84977-0C020 Drive Monitor Switch
- 82143-0C030 Wire Instrument Pan (although I didn't need it, derp)
I checked the display with a flashlight, and it has the MPG text, not that is a sure fire thing I guess.
Am I missing something obvious? Do I need to switch pins or something?
Is there anyone in the D.C. area that has done this mod and willing to help me out? I’ve got 8 wires to the switch so I assume it’s just a matter of adding the two wires at the J28 to JL1. For some reason I can’t view the images on the first page with all the instructions.
I havent done the mod myself but if that harness doesn’t have the right wires in it, you might have to canablize one to make the other work. Im looking at doing the same thing too since it’s cheaper to order a harness and pull 2 wires versus buying the 4 other repair pins. Let me know how it works out for you. If you get it to work please share how you did it.
I ended up cannibalizing the extra wiring harness I had and re-pinned the two connectors, as per the instructions, and it works now.
Good job on the write up! Added my buttons last month. Did not get a deal on buttons, paid full price plus shipping. I had to add two wires from the front to the back of the instrument panel. I sourced the needed pins from an '07 Camry I found in the local LKQ. I had to add the two white wires from the front to the back of the instrument panel. I re-hooked the battery, turned the key and it worked like a charm.
Thanks for the write up!!
2010 tundra dc grade. I’m trying to recycle my sonar wires. I got them switched to the correct pins on the switch connector but I can’t remove the pins from connector jl1 to be able to switch them. Is the lock on that plug suppose to come all the way out like the plug on the switch did?
EDIT: no, it only pops up 1/8” and you can remove the pin while prying from the front. I used a shaved down paper clip.
My truck seemed to be different in that it was a 2010 with 6 wire switch but there was existing wires in the gauge cluster connector at the correct pin locations so the only wires missing were between the switch and the jl1 connector, being a grade model without sonar I was able to relocate the sonar wires as instructed under the 2011+ diy (even tho they said blue and purple, pins 4 and 5 - mine were reversed- but the end location is correct) and it works now.
I have a 2013 Double Cab 2WD Base/Grade. I already had 8 wires at the switch but I couldn't get it to work adding the wires from J28 to JL1. Instead I connected J28 Pin #28 to JL1 Pin #17 and J28 Pin #30 to JL1 Pin #19 and it works!
I also purchased a wiring harness that I don't need, 82143-0C030 WIRE, INSTRUMENT PANEL, make me an offer!
Just picked up the Toyota 84977-0C020 Drive Monitor Switch from amazon ($99.94, free shipping from Evans Toyota) and installed it on my 2013 Tundra CrewMax 5.7 4X4 Flex Fuel(SR5?) and it worked plug and play. My plug had the 8 wires preinstalled and I can get the AVG MPG, Inst MPG, Temp, Dst to Empty, and blank screen. I can also change the units and I was able to reset the default MPG which was 12.9 when I first installed the plug.
I just completed this in my 2008 SR5 DC. The write-up was very helpful and easy to follow. For some reason, the pictures would not display for me however I was able to find a schematic of the J28 harness online so I would know which pins/slots to use. Went well, just be sure those wires are really snug and are down pretty far into the harness, I had to make a few attempts at this to get a good connection.
Went out and took a look... I do have the MPG stuff on the accessory meter. Also, mine already has the stuff for the sensors that they put on some vehicles that detect approaching obstacles (i.e. the pole you cannot see behind you!!) I may actually call the kid at the dealership i bought this from and see if he will let me come out and swap out the buttons between my truck and one on the lot just to see if it works before I buy the drive monitor switch... im sure if they knew about this they would enjoy installing them on trucks and charging a little extra for the "Bonus Features".
EDIT:
Also, popo2239... when you originally installed this, did you have the 8 wires already on the blank button panel or just 6?
Just did the install on my 09 RCSB. , works just fine. I just folded the wire as well , maybe get the pins later on.
Question tho , just tried doing my sons truck , he has no sonar on his truck only the temp works. There are 8 wires at the monitor switch. As for pins 28 & 30 at the J28 connector they are not empty yet the pins at JL 1 For # 17 & #19 are vacant ?? Puzzeled as to where to run my wires ? Any tips on this ?
2013 Toyota Tundra 5.7 SR-5 TRD
Anyone know what wires are 17 and 19 on the JL1? I can not find out which ones they are any where on line.
I just purchased a 2013 Tundra DC 5.7L 4x4 GRD (not sure what this means). The switches were all blank but the harness behind it had all 8 wires. I did the two wire mod (JL1 to J28) with connectors I had leftover from my RC hobby. However, the only thing that works is switching the temperature from C to F. Is there a way to test continuity from the JL1 connector to the switch to make sure that my wires are properly connected between JL1 and J28?
Can I test continuity between DMC #2 and JL1 #17 and between DMC #3 and JL #19?
I have read through the original post and all of the other posts. I seem to have an odd ball wiring scheme. All of the pins have wires in them on J28 and JL1 but they are not the correct colors. I have an 8 wire harness at the drive monitor switch but the wires between JL1 and J28 don't seem to match anyone else.
Anyone have a suggestion on what pins I should use or how to get this to work?? All of the empty pins are in the wrong spot and none of the wires matched. I'm stumped.
I have a 2008 Tundra 5.7 L V8 with bench seat.
154791
