I am lifting my 2002 2wd tundra:
Does this sound like everything needed:
2.0 SAW's
Bilstein 5100's for rear
1" lift block for rear
These are the products I would like to buy, is there anything else I am going to NEED?
Sounds good. I would suggest the urethane steering bushings because you are proabably going to run bigger tires as well which will put more force on the steering. And for only 20-30 bucks it is a cheap thing to do.
Check your brakes while in there to make sure they are looking good because stopping is also hindered by the bigger tires
You should do an alignment after all is completed.
