Have anyone has this problem? I tried to take the seat out and check the latch system. Could not find anything wrong with the seat but it could not latch on. When drive over a bump, it can easily tip forward and fold back down. Driving me crazy.
Anthony
Which seat are you having the problem with? Is it the second or third row? I've had my second row not lock all the way, and bounce up on me. It was just a matter of folding it back up, and put it back into position. Sometimes you might get the hinge in the closed position, so you could try to pull the lever and see if that will unlock it.
Third row is a bit more tricky. There doesn't seem to be a real clear cut way to slide them in and or remove. I've always had to do it a couple times before it works properly....even when following the instructions.
