Throttle Body Cleaning
1 reading
1.7K views 7 replies 4 participants last post by  boofer
#1 · (Edited)
Hello. I've been trying to figure out why my truck has been idling low and constantly dying. After a lot of "research" I decided to clean my throttle body. I opted to completely remove the throttle body. The procedure in the Haynes manual is better than in the factory manual and was actually quite simple. I was blown away how dirty this thing was! I spent at least 2 hours cleaning the throttle body and I only used throttle body cleaner. I only used a clean shop towel and an occasional Q-Tip. I hope this fixes my problem.
#4 ·
How much more horsepower can I expect after treating my vehicle with Sea Foam ?
Turns your Briggs & Stratton into Col. George S. Patton!
You turn a Neon into a Viper!
You turn a PT Loser into a Power Wagon!
You turn a Pinto into a Mustang!
A Le Car into a La Ferrari!
Says so right on the can.
#8 ·
My TB was very dirty. The pictures don't show it well. Plus, the gasket was brittle. I gander that this was the first time it had been removed and/or cleaned. And, the two nuts and two bolts were definitely overtorqued! All in all the cleaning was easy except for the cold weather.
It solved my low idle and stalling problem! Next, I had to diagnose and fix my MAF.
