Very new here and newbie so just learning. I bought my wife a FJ62 and have really enjoyed working on it so diving into doing the same with my 2002 Tundra. Love that truck and want to have it in 20 years as well like this cruiser so need to learn it.
Already got some help on rack and pinion question, but now onto the timing belt. I had it replaced at 100K, but now at 210K and need to do it. Was really thinking of doing it myself to learn the truck better. Few questions for the experts:
1) how much time should I set aside for this? Weekend enough?
2) Other than the water pump what other pulleys and or seals should be replaced? I plan to replace my alternator while in there being that I am starting to have high voltage readings on the gauge and since I am already in there...
3) Is there a good manual to follow for the truck other than the Service Manual that is $220?
4) This is the only part that concerned me. Fast forward to 13:00. He is putting something back on between 13-13:45 and I can't tell if he is tightening it or adjusting it to required specs. That pulley is moving around and he doesn't talk about it. Just don't want to think I got it and screw my engine up.
5) In reading timing belt threads one member mentioned using toyota's in place of gasket RVT for the water pump. Is that how it came stock or with the gasket? Any reason to use it over a gasket?
Well thanks for reading all this and appreciate any input. I know there are a lot of threads on timing belts and I have read a lot of them.
