Moose cat, first off I have been assuming this is a V8 engine in my procedure descriptions. I am still leaning towards a stuck valve. A couple of approaches come to mind. I have a cheap, $20 bore scope that plugs into my cell phone. MIGHT be able to see with one of those which cyl is at the top of its stroke when the blockage occurs. Also might try carefully turning crank until it stops and since you have the plugs out take a long dowel or a long screw driver and put it in the spark plug holes to determine piston location. Problem is that there is probably one on each side at the top of its stroke at the same time.
I am kinda spitting in the wind here but your next step might be removing a valve cover because knowing which side is messing up would be a big plus. So that means new VC gaskets and might as well replace the spark plug gaskets while you have the VC off. Note: there are little tabs holding those SP gaskets in place. Bend the up, replace gasket, tap them flush. With the VC off have someone GENTLY rotate the crank when it is a the blockage point and maybe you can hear, or feel by placing your hand FLAT on the cams which cylinder is bumping into something.
Sorry to say this out loud, but you may be removing a head or two. Reality is that if it is, by chance, a valve it has to be reckoned with. I would be cautious if it was just freed up and then then buttoned back up and driven. I didn't say I wouldn't do that, but I bet you would rather deal with the underlying cause than have a broken something flying around inside of a cylinder.
Just don't get frustrated or discouraged. This is a blessing that it showed it's ugly head and you get it taken care of now while you have it opened up rather than becoming a story you share with a tow truck driver on the side of the road where the engine went belly-up. Every new adventure is a learning experience, and usually a pain in the butt. Hope this has been some help. Where are you located? There may be someone on this Forum nearby willing to help you chase this issue down.
By the way I woke up at 3:am as predicted... LOL Chap
Well I guess I’ll take the VC covers off and see what’s going on. I order a camera so with the covers off it might make it a little easier to look into. Ty very much for all the info, wish me luck lol PS were in Montana where are you
