Hello,
>>> 1) Has anyone changed their Timing and Serpentine Belts? If so, How would I take the 2 Serpentine Belt off from "Comp. and Alt." and one from "Power Steering"? I know there should be a pully to yank to loosen the belts, but can't locate it. Is there any? Cause I know there is one in Timing Belt area. So would you say I could do the Serpentine Belt change w/o taking out the timing belt case cover?
>>> 2) Could I use Bosh "Platinum IR Fusion" Spark Plugs, or just stick with Iridim-Tipped Spark Pulgs?
Thanks:tu:
Thanks:tu:
