2005 - is the spare part of the sensor system? All my tires are fine but the light is still on. Tried to check pressure on the spare but it's not accessible unless lowered....
Yes it is.2005 - is the spare part of the sensor system? All my tires are fine but the light is still on. Tried to check pressure on the spare but it's not accessible unless lowered....
Thank you.Yes it is.
i have the same issue. Granted, i did not add air to the spare. only to the four tires on the ground. light is flashing, so annoyingAlong the same lines, I had air put in my spare and the light went out.
A couple days later it's blinking.....????
Now what?
I read that if it's blinking their is a failure in the system....i have the same issue. Granted, i did not add air to the spare. only to the four tires on the ground. light is flashing, so annoying
