Does anybody know what the tire re-set button does by you right knee? I mean it say re-set but is that for you to re-set your light if it comes on for low air? Or is it for if you change the tires and they are little bit bigger and take more air to set the air level for the light since you had to use more air?
When you change tires and the max tire pressure changes, its so you can reset it to the new pressure. For the best info look it up in the manual!!
Thanks, I would of looked it up but don't have the manual for the truck. Daughter cleaned truck one day for me and cleaned out glove box and never seen it again.
Thanks again
Wolvie
The reset button is for resetting the TPMS system and the procedure is more than just pushing the button. Do a Google or Yahoo search for toyota iguides That will take you to a link for a downloadable Owner's Manual.
