1 - 7 of 7 Posts
I need some info on tire size, I have looked through the fourms and cant find what I'am after I'am putting a 3" toytec lift on my truck but i dont have the money to do wheels right now, my tires are wore out so I was going to put new tires on the stock 17x8 wheels, whats the best tire size for stock wheels and the 3 inch lift. Thanks
on a 17" wheel it will be 285/70/17 for the same size tire
I have the same Question. I have the 3" truxx leveling front and 1" block back. looking for tires for my 17" rims this is on 2006 DC 4x4 limited. The factory tires were 265/65/17. the size (diameter) for these for bf goodrich at ko 30.7". for 265/70/17 = 31.8" the don't offer 275. next would be 285/70/17 = 32.7" But what i have read on TS that i would have to cut my flares. i looked at other brand they are all pretty close. what will fit with out cutting any thing and not rub. somebody please help my tires are almost bald.:scared:
See if any of these sizes work.
250/80 R 17(33 x 9.84 x 17)17"9.84" (250mm)32.75" (831.80mm)-0.08" (-2.10mm)
255/80 R 17(33 x 10.04 x 17)17"10.04" (255mm)33.06" (839.80mm)+0.23" (+5.90mm)
260/75 R 17(32 x 10.24 x 17)17"10.24" (260mm)32.35" (821.80mm)-0.48" (-12.10mm)
265/75 R 17(33 x 10.43 x 17)17"10.43" (265mm)32.65" (829.30mm)-0.18" (-4.60mm)
Professional Driver
I would run the 285's. The cut you will have to make is only like 1/2" on the inside front of the flare. Noone would ever notice it even if you pointed it out. I didnt want to cut my truck either but I am very happy I went with 285's.
don't think they make 260's and 80 series. most of those won't work anyways.
try this.
Car / SUV / Van / Light Truck Tire Calculations
on a stock wheel, you can go 285/70/17 or 285/75/16 with some rubbing at full lock. if you don't want any rubbing issues, go with 265's. a simple search would have given you TONS of info though. :)
1 - 7 of 7 Posts
