ZL,
You might check out this link and see if it helps you with different scenarios
http://www.rims-n-tires.com/info_sp...l&sw1=315&ar1=70&bd1=17&rd1=17&rw1=8.0&et1=10
I tried putting in your current size and a possible increase (in sidewall height). The main problem I see is that to go taller your are going to have to go narrower more than likely to get it to fit.
Hope this helps. By the way it looks like you are just down the road from me.
