I have a 2008 Sequoia 4X4 and have a couple questions in regards to what I'm seeing on my vehicle. First off the rear tires have way too much negative camber and the front has too much positive camber. I'm sure the manufacturer has it this way for stability and to promote understeer, but I would prefer to have a little more oversteer adjusted into my SUV via more negative camber at front wheels and more positive camber on rear tires.
In regards to toe in, I have 1/2 inch toe in and would like this to be adjusted to more toe out so wheels are exactly straight forward or no more than 1/8 inch toe in.
My front toe in, as well as, my front positive camber is causing the outer edges of my tires to wear more than the inboard side of tires. I rotate my tires frequently, but still get uneven tire wear. I just replaced my OEM tires and they had 2/32 of more tread on the inboard edges of tires as compared to the outboard edges.
Took Sequoia to dealership and they said all specs are within limits and they wouldn't make any adjustments. What are my option? Does anybody have instructions on how to adjust toe out on a 2008 Sequoia and adjust rear tires so they have more positive camber? The front toe adjustment looks pretty easy, but the camber adjustment looks more complicated.
Any help would be appreciated.
