Supporting Vendor
An adventure that takes you off the beaten path and into a non-treaded terrain can be exciting, daring, and thrilling in case you have the right tires on. Often overlooked as an important aspect of adventure, off-road tires can make all the difference for your off-road driving. Especially if these tires are from Nitto - an American legendary brand of tires.
These tires have deep, self-cleaning independent tread blocks and linear transverse flex zones for combating off-road obstacles. They feature aggressive sidewall lugs, as well as the cut- and chip-resistant sidewall compounds. All these features make Nitto tires perfect for mudding and pushing your rig to the limit. If you need advice on fitment or pricing - please call us directly at 888.978.3395!
#1 Nitto Ridge Grappler
Features:
  • Latest generation drive axle tyre
  • Delivering superb traction in all weather conditions
  • Casing and new tread design ensure even wear and top mileage for all needs
  • Outstanding all-weather performance
#2 Nitto Dune Grappler
Features:
  • The intermediate void ratio between the tread blocks helps to provide off-road performance in loose dirt and sand
  • Three-ply polyester sidewall construction(depending on the size) and sidewall lugs aid in puncture resistance
  • The Dune Grappler’s 3D grooving and tread blocks help reduce tread movement. This helps reduce irregular wear and minimize road noise
  • Bridges were added between tread blocks to reduce tread flex, resulting in less heat build up to prolong the tire's performance
#3 Nitto Exo Grappler
Features:
  • A special mix of natural rubber, high strength polymers, and wear-resistant materials aids cut and chip resistance on unpaved gravel roads
  • The staggered shoulder blocks provide biting edges for off-road traction in loose dirt surfaces
  • The computer analyzed tread block arrangement reduces tire noise normally heard at highway driving speeds
  • The gear shaped block edges reinforce center tread blocks and provide a stable contact patch
