Does anybody have an FSM or know the torque specs for mounting shocks?
I just got a set (all four) HD bilstein shocks and struts. Need to know the correct torque spec for the mounting nuts. I have searched but found no numbers. An help would be appreciated.
Its a 2000 access cab if it makes a difference
· Super Moderator
Front
Shock absorber-to-lower control arm nut -- 100 ft/lbs
Shock absorber upper mounting nuts -- 47 ft/lbs
Shock absorber damper rod-to-suspension support nut -- 18 ft/lbs
Rear
Shock absorber-to-frame nut -- 15 ft/lbs
Shock absorber-to-axle bolt/nut -- 64 ft/lbs
