Anyone have torque specs for 2009 Camery v-6 and 4 cyl OIL DRAIN PLUG?
I'm looking for something I can print that shows what the manufacture calls out for on this.
Thank you very much in advance!!
Conk:snoopy:
the dealer is supposed to torque the drain plug to no more then 40 lb-ft. this is the spec for a 4 cylinder solara.
I think you are confusing the nm value with ft/lbs.
Conk: This is for Tacoma but I am pretty sure torque specs are the same since it has to do with the type of materials used and they all use the aluminum pans these days. Hopefully someone else can get you Camry TIS but it will be the same. Scroll about halfway down the thread.
http://www.tacomaworld.com/forum/2nd-gen-tacomas/6754-oil-pan-drain-plug-torque-spec.html
