1 - 14 of 14 Posts
So.... I got into a pickle today and had to reverse over a rather large sage brush. Didn't think it would do anything to the truck.... Does anybody know what the easiest way to fix this is? As is sits now, I have used bailing wire to keep it form hanging. I'd rather not live with this option...:td:
Besides, if you really are an advocate of sage...lets rap! I'm a biologist...and can give a million reasons why sage is suffocating our rangelands....anyway...neither here nor there...
I'm not sure how to fix it, but I had to buy the harness from Toyota (used car lot removed it to put on another truck) and I cost me about $300 Canadian. I wish you luck in figuring it out.
Go to walmart and look for the same plug setup. Go splice the new plug to the old wiring and be done.
This is what I would do, with the exception of finding a nice high quality connector @ a trailer supply store. $300 for a harness & connector is a joke.
Discussion Starter · #13 ·
Not sure if it's the same or not but I have a new wiring harness for a 2000 Tundra that I never installed. Traded in on a 2006 4 years ago, never installed it on the 2000.
If its a 7 pin and you have the mounting bracket attached to it, then lemme know! I might take it if it's a sweet heart deal!
· Premium Member
I think they should be identical, but worse case scenario you can pull pins out and put yours in
EDIT: I am 90% positive that it will work with your truck (since Lexus GX, LX, Toy Sequoia Tundra) have same connectors, so why would Tacoma change theirs?
1 - 14 of 14 Posts
