here is the problem. We have a 1994 toyota camry LE 2.2L The car starts up just fine and runs great except one small problem. When you shut the car off to take out the keys, you CANNOT take the keys out. The only way the keys can be removed is by DISCONNECTING the BATTERY. Thanks!
Automatic I assume? Push the transmission selector toward the front in P more, it may be worn out and thinking the vehicle is still in gear.
and use some graphite grease to grease the lock and tumblers because they are surly dry after 20 years
