I am probably going to get the toytec boss lift or radflo stage 2 for my 1st gen anyone know if I get aftermarket bumpers if those shocks will do fine or if I’ll need different ones ? Or would a radflo stage 2 be a better option for my lift those are my two options due to the toytec has a diff drop, bump stops, total chaos or spc uca and 2” rear block in back and I know radflo is a good good brand just want to know which would be better and what option for shocks to get for aftermarket bumpers that’ll work with either kit
Bumpers shouldn’t have too much of an effect on your suspension set up unless you get really wild and do new mounts and reservoirs and hydro bumps and so on. It doesn’t sound like you’re doing that so you should just pick the best suspension you can afford and go for it! Good luck and post pictures when you get your lift on!
