Read on forum some stories, but wanted to see if anyone has ever had TPMS light to stay lit on the dash. All 5 tires are 32 psi, and I've re-initialized the system per the Manual, light still on. I read where someone suggested deflating the spare and then reinflating, will try it next week.
Anyon else come across this issue and solved it? Thanks (PS No recent tirework).
Not sure if you have resolved this issue yet.
I believe the manual is incorrect or at best misleading.
It states to reset the system when the tires are cold and at proper pressure.
That part is correct.
The part i believe is incorrect is that it says to press and hold the button while the ignition is set to the "on" position.
That did not work for me.
What did work was with the ignition off, press and hold the reset button, start the truck.
Now the ignition is in the "on" position.
The light should blink slowly 3 times. Mine blinked twice. Who knows???
But that did the trick for my 07 SR5 Sequoia.
FYI- bought with 27k miles. Now have 53k. No major problems other than the ticking noise. I love this truck!!
