1 - 7 of 7 Posts
Have a 2000 V6 tundra.
Anybody else have trouble checking trans fuild.
The dip stick is hard to insert back in. Have to use two hands and sometimes get stuck about 1/2 way in and wont go in or out. Have to put a lot of force on it to get it back out sometimes.
The dip stick looks like it has two twist in the stick. Is this normal.
Never had a vehicle that even was half this hard to get the dipstick back in.
Any suggestions
thanks
· Premium Member
Any suggestions
thanks
I did a full transmission flush yesterday. I must have run that stick in and out 50 times. What I do is just support the top of the stick and run the thing into the filler 6 inches or so at a time, putting the force down low on the stick, close to the filler neck.
This is the same procedure I use. What a pain.....:(
· Premium Member
That's why yo should take it to Toyota and let them fix it!!:)
Fix it?
It seems to be a design flaw to me.
The filler neck is smaller in diameter than most too, about 3/8" as opposed to the 1/2" or so that you would expect. A standard long neck funnel won't fit snugly enough to pour ATF down there without making a mess.
Usualy there is a bend to it that takes place after sitting for so long in the same position from the factory. I try to put it in the exact same way everytime, seems to be eaisier that way.
· Premium Member
No apparent set to the stick at all. It's been like this since the truck was new.
1 - 7 of 7 Posts
