So my 2011 Sequoia is right at 180k miles. I purchased it about 1.5 years and it's been problem free. About 6 months ago I noticed that when chugging up a hill at slower speeds (maybe 30 mph) at a constant RPM, it felt like the engine would rev up slightly (maybe 100-200 rpm) and the pull felt a little less. I wasn't sure it wasn't a misfire, but no DTC were thrown. It was intermittent and infrequent enough that I'd forget about it before getting home. On one of the earlier service calls at the dealer, I asked them to check the transmission - which they reported as "everything checks out". I don't know what that means, and the dealer's technical prowess is sub-par (and that's being nice)
Over the last few weeks it has gotten noticeably worse. Now on climbs I can feel the pulling power drop by about 50% for about 3-4 seconds, then a thump as the full power reengages. RPM is staying relatively constant, so I'm certain it is the transmission. Some times, when it's cold, and I put it into drive initially, I press the accelerator, and it barely moves forward - almost as though I put in into neutral instead. After letting RPM back down and waiting a second, all goes back to normal.
Further complicating diagnostics is that most of the roads I travel are hilly and gravel - something that helps obscure the slipping.
There are no visible leaks (though I do park in gravel, so I may not have noticed any), no burning smells, nothing out of the ordinary.
I'd be happy to check (and maybe even change) the transmission fluid, but I was under the impression these were "sealed for life" devices - at least that's what the dealer has told me.
