TRD Alloys for towing?
1001 Views 1 Reply 2 Participants Last post by  SE2000
We have a 2010 Platinum which we'll use primarily for work. It's other use will be for towing our travel trailer on vacations, 8000lb ready to go. My question is, would a different set of wheels with more sidewall and a better load rating then the 20's, improve my towing weight/experience/safety?
I see that the 2010 SR5's have a tow rating substantialy higher then the Plat's. . .
TRD Wheel -17 inch Forged Alloy ONE (1) (PTR45-34070)
More sidewall, no, more load capacity, most likely. Your tow rating is less because your truck weighs more. You have to subtract that. I think a sway bar and maybe air bags or roadmasters may be your first choice if you want/need to upgrade.
The last wheel I'd get to tow with would be the 17" factory wheel
