Does anyone have part #'s for what it would take to put the TRD PRO Sequoia grill on a truck that didn't originally come with one? I'm not a big fan of the grill on my TRD Sport and I think the 2020 TRD Pro grill would be an improvement.
Part number PT363-0C200-BL is the TRD Pro Grill. Parts.ElmhurstToyota.com had it in stock and was priced competitively. Install was super easy and took about 20 minutes.
The stock TRD Sport grill was the only part of the truck I didn't like - I think the TRD Pro grill is a big improvement. In the spring I might swap the chrome pieces from the stock grill to the TRD Pro grill but it's too cold to mess with it right now.
Hi, please help! I am trying to swap my grille out to the TRD pro one. After I unbolt all the bolts, how do I detach the grille from the hood?
Are there hidden bolts anywhere? Tried to pry it out but don't want to force it too much.
Thank you for any advice!
I did it. Took about an hour and a half taking my time. That doesn't count the extra hour I used going to the dealer to replace a couple of body clips that broke
First mods on my 2019.
I have mine and it looks like you reuse the top body colored part that attaches to the hood and the grille. It shows removing 7 clips but I don’t have access to those. How do you remove that part to get the grille out? Just pull it up?
I just picked up a 2011, and my better half has already said she wants new skins, a small lift, but first she wants the "TOYOTA" grill as she calls it. I had thought that all 2nd Gen Sequoias had teh same grill opening, but I figured I should doublt check with those of you have have a better info base. Thanks for any replies!
Does the little rubber strip between grill and hood stay on with the pro grill? Mine has disintegrated and curious if it looks fine without it on the new grill? I think it looks better without on my current chrome stock grill(transition looks fine and no longer have a black strip) but my new grill shows up this week and need to run to dealer to get that rubber piece if I’m gonna need it
Related Threads
Toyota Tundra Forums
1.8M posts
264.7K members
Since 2002
Tundra Solutions Forum - the best community to talk, mods, price, repair and research your Toyota!
