21 - 29 of 29 Posts
I did it. Took about an hour and a half taking my time. That doesn't count the extra hour I used going to the dealer to replace a couple of body clips that broke :)
First mods on my 2019.
I have mine and it looks like you reuse the top body colored part that attaches to the hood and the grille. It shows removing 7 clips but I don’t have access to those. How do you remove that part to get the grille out? Just pull it up?
Yes, they are hidden body clips. I popped it off with a plastic pry tool. I also broke two of the clips.
I just picked up a 2011, and my better half has already said she wants new skins, a small lift, but first she wants the "TOYOTA" grill as she calls it. I had thought that all 2nd Gen Sequoias had teh same grill opening, but I figured I should doublt check with those of you have have a better info base. Thanks for any replies!
Does the little rubber strip between grill and hood stay on with the pro grill? Mine has disintegrated and curious if it looks fine without it on the new grill? I think it looks better without on my current chrome stock grill(transition looks fine and no longer have a black strip) but my new grill shows up this week and need to run to dealer to get that rubber piece if I’m gonna need it
14’ Sequoia Limited
This TRD Pro grill upgrade will fit all Sequoia's from 2008 and up.
21 - 29 of 29 Posts
