Status
Not open for further replies.
· Premium Member
NOTE 2005 D-Cab - The door trigger wires are negative and found in the BECU above the driver kick panel. The colors are as follows. The LF door is gray/red, gray plug, pin 15. The RF door is lt. green/black, black plug, pin 8. The LR door is red/white, gray plug, pin 16. The RR door is red/white, black plug, pin 4. Use all four wires and diode isolate each.
2006 Double Cab
http://www.directechs.com/directwire/wire_body.asp?action=select&yr=6097&product=Remote Start
http://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1070.pdf
Status
