1 - 7 of 7 Posts
Like your door will not stay open unless the truck is sitting perfectly level? My truck does that and I would like to fix it if its easy and cheap
My driver's side door check also does this, has anyone changed this out yet?
I am wondering if you can change it without taking the panel off.
Nope...it's installed from inside the door. Once you detach it from the body, you unbolt it from the door and pull it inside the door. To install, you push it from inside the door and attach it to the door...and then attach it to the body. :D
1 - 7 of 7 Posts
